13 years agoQuartus commands executed while working with Quartus GUI
Dear all I would like to automate my work using the Quartus commands executed when i use the Quartus GUI For Example : Step 1: I will open the signal tap file using Quartus Ste...
13 years agoSorry, I hardly understand :
You want to extract "data log" from signaltap files, don't you ? For this, you can use MATLAB MEX function, see design debugging using the signaltap ii embedded logic analyzer chapter of the quartus ii handbook (http://www.altera.com/literature/hb/qts/qts_qii53009.pdf) I don't know this tool. Or you can "export" "data log" to .CSV by script (precisely TCL script) : see http://quartushelp.altera.com/current/mergedprojects/tafs/tafs/tcl_pkg_stp_ver_1.0_cmd_export_data_log.htm You write a tcl script (text file for example "myscript.tcl") for quartus stp which looks like :
# package require (I add this)
package require ::quartus::stp
# opens signaltap session
open_session -name stp1.stp
# capture data to log named log1, timeout after 5 seconds if no trigger occurs
run -instance auto_signaltap_0 -signal_set signal_set_1 -trigger trigger_1 -data_log log_1 -timeout 5
# export data into a VCD file (I have corrected the command)
export_data_log -instance auto_signaltap_0 -signal_set signal_set_1 -trigger trigger_1 -data_log log_1 -filename log_1.vcd -format vcd
# close signaltap session
close_session
Save the file to your signaltap file directory In a standard Windows terminal, go to your signaltap file directory and type : "quartus_stp -t myscript.tcl" I haven't tried things like this, So no warranty. This is for ONE stp file. If you want to automate the process for multiple file you had to run the script for each file, many ways to do this (possible in tcl script but if you don't know TCL scripting, you will spend a lot of hard hours). If you really want, I could answer. Good luck !!NuvKFC
Contributor
5 years agoHi Altera_Forum, sorry to bother you. Could you please tell whether "open_session" command can open SignalTapII GUI, and the user can use this SignalTapII GUI to add nodes? Thank you very much.
