13 years agoQuartus commands executed while working with Quartus GUI
Dear all I would like to automate my work using the Quartus commands executed when i use the Quartus GUI For Example : Step 1: I will open the signal tap file using Quartus Ste...
13 years agoThankyou for the reply
"Do you want to automatically convert the format from hex to binary in multiple signaltap files ?" I was given multiple signaltap files(having acquired data) for analysis, My work procedure is as wollows 1) convert the signaltap II files(having acquired data) from hex to binary 2) save the signaltap.stp 3) Create a signaltap II list file which is a txt file I use this text file for analysis in Matlab But since i was given many signal tap files for analysis , i think automating of creation of signaltapII list file would be helpful to reduce my task Also i am thinking that for every action we do in Quartus GUI should have a script running in the background So i want to see these scripts executed to automate my work May be the solution you provided can help me to change the stp from hex to bin but i cannot extract the signaltap list file for analysis
