Randy1
5 years agoQuartus appears to sometimes, incorrectly report Blank Check Failures
Our production programming station has reported intermittent blank check failures even though they have performed the erase operation prior to the blank check. The JIC file was read back from the sus...
JohnT_Altera
5 years agoHi,
May I know if you are facing any issue when directly programming the new jic file without the blank check?
Have you try to performed erased 1st and then only performed blank check? In 2 different flow
- Randy15 years ago
Hello, It turns out that the production test folks have tried the two things you mention.
1) If they Program and Verify only (with no blank check), they have not observed any failures.
2) If they Erase and then Blank Check over and over, they observe intermittent failures.
In at least one of the cases where they did and Erase and observed a Blank Check failure, they read back the device and were able to show that it was actually blank.
