Randy1
5 years agoQuartus appears to sometimes, incorrectly report Blank Check Failures
Our production programming station has reported intermittent blank check failures even though they have performed the erase operation prior to the blank check. The JIC file was read back from the sus...
JohnT_Altera
5 years agoHi,
May I know which blaster are you using to programmed the device, error message shown in Quartus Programmer and could you share with me your full JTAG chain for your board?
Randy1
5 years agoHello - I am using the USB Blaster in my Engineering setup which I believe to be same as the one that Manufacturing test is using, but I will confirm this. Attached is the JTAG cdf file. The error they described was just Blank Check failure without too much more information, but I will follow up with a screen shot.
