18 years ago
Quartus 7.1 Sp1 and DSPBuilder 7.1Sp1
Hallo everyone,
I have a problem with my Installation. I have installed Quartus 7.1 Sp1 and DSPBuilder 7.1Sp1.
If I want compile any Example Model like "singen" an error occured.
The SignalCompiler shows the following message:
Created Quartus II Project C:\altera\71\quartus\dsp_builder\DesignExamples\Tutorials\GettingStartedSinMdl\singen_dspbuilder\singen.qpf
Generating HDL
Analyzing model...
Matlab Error
Java exception occurred:
java.lang.UnsatisfiedLinkError: checkOut
at com.altera.dspbuilder.portmanager.PortManager.checkOut(Native Method)
at com.altera.dspbuilder.serialisation.ModelSerialiser.<init>(ModelSerialiser.java:88)
Error during generation: Analyzing Error: See log for details.
Has anyone an idea who is the problem? or where I can found the log file?
So long
Mario
    Ok, I've read carefully DSP Builder User Guide and found a source of a problem.
    In Troubleshooting chapter I found the "DSP Builder StartUp Dependencies", checked all error possibilities and found this note:
    "4. When Cygwin is installed, make sure that it is listed after Quartus in
    the path. Correct environment settings in Cygwin do not guarantee
    that Signal Compiler will start properly, as DSP Builder relies on
    DOS settings rather than Cygwin. (When MATLAB is started from a
    Cygwin command prompt window, system env in the MATLAB
    command window only reflects the Cygwin settings.)"
    and..
    "5. If there are any other operation systems, such as WinVar, installed
    on top of Windows, make sure that they are listed after Quartus in
    the PATH environment variable."
    I have Cygwin installed on my computer and when I done everything according to point 4, then DSP Builder started to work :)
    Cheers!
