11 years agoQuartus 2 13.0sp1 Hardware debugging issue
Hello, I have started using the DE0 board, normally i write my code in C then debug it as hardware on the DE0 for certain Universitie projects, the issue that I'm facing is that on one of my PC...
11 years agoAre you still having problems with this...?
Can I assume you've installed Quartus and Nios EDS onto the new machine or... --- Quote Start --- the driver for the DE0 board is installed manually from the programmes directory... --- Quote End --- Have you simply copied all the files from that folder between machines? If so, what is setting up your environment variables? Happy New Year, Alex
