syam
4 years agoQuartus 18.1 - CYCLONE V Preloader issue
Hi
Am working on a project with CYCLONE V - 5CSXFC6D6F31C8N with Quartus 18.1. After compilation in emif.xml file in the hand off folder the SDRAM related clock info is being written as 0 by quart...
aikeu
4 years agoHi syam,
I cant be sure regarding most of the parameters at the moment.
Does the specic values for DDR clock 118MHz relected in the emif.xml file?
I see that your F2S_SDR_REF clock is 0 KHz even you have set to 50Mhz, I think is because the bridge was not enabled yet.
When in u-boot, you can run the cmd "bridge enabled" and if possible check any changes to the F2S related clock values.
Aik Eu
syam
4 years agoHi Aik
Thanks for the response. 118MHz is not reflected in the emif.xml file.
The boot log is from the preloader before u-boot.img is loaded. So am not sure how to do the bridge-enabled stuff. Can you please share the procedure to do so.
Best Regards
Syam
