Quartus 18.1 - CYCLONE V Preloader issue
Hi
The image you have sent cannot be opened.
There is definitively a problem with the preloader generation. I set the clock for the DDR3 from the FPGA at 50Mhz. But the preloader bootloader shows 0.
Hi syam,
Sorry that I am not aware the image is not able to open in the community forum page. I was using another link to upload the image.
Below is the image, refer to the default values of the IP:
You can try to check the hidden parameters of the IP in platform designer to verify again the difference before and after generate.
The hidden parameters can be displayed when right click on the blue gradient part of the pic above.
Aik Eu
- syam4 years ago
Thanks. Can you please point out where the hidden fields relevant to the marked items in the boot log are located ?
