9 years ago
Quartus 15.1.2. use Design partition with In-System Memory content Editor
Hi Everyone,
Does anyone know if it's possible to generate design partitions (qxp file) that contains memory that I can access via In-System Memory Content Editor at a higher level?
- I'm using Quartus 15.1.2
More details to explain my issue:
1. I have a sub module that contains a memory instance (which is created with megawizard with option Enabled for In-System Memory Content Editor")
For example this memory instance is called "Mnew"
2. Then I export this module as "submodule.qxp" file.
3. I import the submodule.qxp file into a different design (a top level)
4. Then generate an image (top.sof file)
5. Then loads the image to a device
6. Then use In-System Memory Content Editor to access this memory instance "Mnew"
I have tried these steps, but the In-System memory content editor only seems to find memory instances at top level :(
    Hi sstrell. Thanks for confirming this.
    I'm looking for an alternative way (last attempt).
    Please let me know, if you have an idea how I can keep a design partition (.qxp file) and at the same time get the ability to use the standard memory debug features from quartus.
    Thinking out loud:
    It seems, the interface connections between the memory instance and USB-blaster has been inferred by the tool.
    Perhaps, there is a way I can add interface ports to my submodule, such that it can be extended at the top-level and get it recognized by the In-System Memory Content Editor?
    I'm pretty sure you can't do this. The .qxp file is meant to be a self-contained file like a design file but doesn't allow connections to it other than those to connect it to the rest of the design.
