14 years ago
Quartus 12.0 Cyclone V , No .sof output
I all,
I use Quartus 64bits 12.0 SP2 with cyclone V (5CEFA7U19C7) and we have not programming output file (0 errors and 0 warnings) .... Here is the output info from assembler:
info (115015): compilation report contains advance information. specifications for device 5cefa7u19c7 are subject to change. contact altera for information on availability. no programming file will be generated.
do you have any idea when will be supported by cyclone v quartus?
Thank you,
Jean Lewis
    sorry no - I'm not aware when they (ALTERA) will add this speed device...
    Thank you,
    Do you have an idea when you would have a new Quartus release to support this speed device ?
    Jean
    I think support will be added as soon as this chip is "available"... Currently the 5CEFA7U19C8 is listed at "buy" - perhaps you should change the speed grade and see what happens?
    Best regards
