12 years agoQsys - Nios write to FIFO
Hello, In my design project, Nios needs to write to an external FIFO. I created a custom Avalon MM component for the purpose. When Nios write to the custom component, the design expects to see the...
12 years agoIts possible that Eclipse was trying to compile your project with an old version of the BSP that didn't have this component, and as a result didn't replace OUT_FIFO_AVALON_INTERFACE_0_BASE with the correct value. I don't use Eclipse that much so I don't know how smart it is when you partially recompile a project.
As for your other line, it looks like you found the solution yourself ;). You should always bypass the cache when accessing a component, either by using the IORD/IOWR macros, or change the address pointer. For the latter you can either set bit 31, as you did, or use the alt_remap_uncached() function provided by Altera, which is a more portable solution.
