12 years agoQsys - Nios write to FIFO
Hello, In my design project, Nios needs to write to an external FIFO. I created a custom Avalon MM component for the purpose. When Nios write to the custom component, the design expects to see the...
12 years agoStill have not been able to figure out the cause of unresolved label issue in EDS software. Re-build the software project from ground up. The problem is no longer there.
The app software writes to FIFO at a constant interval. However, per the waveform on the scope, it looks as if FIFO was written to only once then the program quit writing. On advice, I wrote to 0x8000,5060 instead of 0x5060 to bypass cache. This last step appears to take care of the problem.
