10 years ago
QSGMII in Altera?
Is it possible to run the QSGMII in Altera?
For example in Cyclone V ST with his transceivers 5Gbps?
I want to connect the Marvell 88E1680 ic to the Altera(Cyc V ST may be).
______________________
* Marvell 88E1680 supports QSGMII (Quad-SGMII) MAC interface running at 5Gbps data-rate.
    currently as I aware there is no example for the type of application that you mentioned. As there is no prove of concept. do you consider to use a normal SGMII? this example already placed in rocketboards.org
    --- Quote Start ---
    no working example for this purpose , currently only with normal SGMII usage only.
    --- Quote End ---
    Thanx for answer!
    Maybe this is suitable for another Altera series(Cyclone V xx, Stratix, Aria...)?
