10 years agoQSGMII in Altera?
Is it possible to run the QSGMII in Altera? For example in Cyclone V ST with his transceivers 5Gbps? I want to connect the Marvell 88E1680 ic to the Altera(Cyc V ST may be). __________________...
10 years agocurrently as I aware there is no example for the type of application that you mentioned. As there is no prove of concept. do you consider to use a normal SGMII? this example already placed in rocketboards.org
