15 years agopulse generator (need help)
I want to generate 25Hz,50Hz,100Hz pulse signals! The singal is bad when I use frequency division! Is there a better way to generate the signals? Thank you very much! --a fri...
15 years agoDo you see the high frequency glitches experimentally?
If yes, did your logic analyzer sample your output synchronously? If not sampling synchronously, it is normal that you see glitches. Remember that you only need that the outputs are stable and have the proper values one setup time before the next active clock edge.
