15 years agopulse generator (need help)
I want to generate 25Hz,50Hz,100Hz pulse signals! The singal is bad when I use frequency division! Is there a better way to generate the signals? Thank you very much! --a fri...
15 years ago --- Quote Start --- Why the signal is bad with frequency division? Do you use schematic or HDL code? --- Quote End --- i use verilog ,the square wave contains lots of high frequency waves! i also use PLL!
