15 years agopulse generator (need help)
I want to generate 25Hz,50Hz,100Hz pulse signals! The singal is bad when I use frequency division! Is there a better way to generate the signals? Thank you very much! --a fri...
15 years agoWhy the signal is bad with frequency division?
Do you use schematic or HDL code?
