15 years agopulse generation with de0 nano
hi, there, i just received the nano board for my lab work. this is my first time touching this fancy board. what i wanna is a output 500ms pulse whose duty cycle is 1/60 (30s per cycle). i am t...
15 years ago --- Quote Start --- You should be able to take the existing design and modify the software. The modifications would involve using a timer to generate the pulses you want. I haven't used NIOS much, so can't comment on specifics. Read through the NIOS documentation and you should be able to find something. I'm assuming you're more comfortable starting with a software solution. If you'd prefer to go the hardware-only route, we can discuss that. Cheers, Dave --- Quote End --- i am confused on the def of software and hardware solution. do you mean i could use the tools like sopc to mod the components or what ever else? thanks for help, Dave.
