17 years agoPull-up On I/o Pin
Bye everyone,
I'm a beginner on Altera software development tool. Can you show me the procedure to set a pull-up on I/O pin, on the documentation i found: "In the Assignment Editor, set the weak pull-up assignment to ON to enable the on-chip pull-up resistor for the pin." but it isn't usefull for me. I'm working with a device of CycloneII, EP2C8F256C7 and Quartus II 8.0sp1 as development tool. Tanks in advance, i'm looking forward for your answer. Bye Giordano2 Replies
Thank you,
I set the weak pullup in Pin Planner. It works correctly. - Altera_Forum
--- Quote Start --- but it isn't usefull for me. --- Quote End --- Why, did you try? The procedure generally works. You also can enable weak pull-ups in Pin Planner, after showing the respective column through customize menu.
