17 years agoPull-up On I/o Pin
Bye everyone, I'm a beginner on Altera software development tool. Can you show me the procedure to set a pull-up on I/O pin, on the documentation i found: "In the Assignment Editor, se...
17 years ago --- Quote Start --- but it isn't usefull for me. --- Quote End --- Why, did you try? The procedure generally works. You also can enable weak pull-ups in Pin Planner, after showing the respective column through customize menu.
