12 years agoPTP 1588 on Cyclone V
Hi I would like to implement PTP 1588 on my cyclone V EVAL kit DK-DEV-5CEA7N. My problem is, I don't find any example how to connect all the ports of the TSE-MAC in the QSYS... ...
9 years ago@lemonoje
There is no PTP reference design for Cylclone. Im using modified "board_update_portal" design. I made some small modifications (TSE Mac, External FIFO, TOD, Packet Classifier). Original BUP design is made in Quartus 12.0, for modification i used 15.1. Wich error you had ? Put the error log screen. Also i found a cause for ethertype.TYPE_NON_PTP. The problem is in Ethernet header offset/* define Ethernet header size and offset */
# define ETHHDR_SIZE (16)
# define ETHHDR_BIAS (2) Now i get ethertype.TYPE_UDP_IPV4 and msg_valid. But egress_timestamp_request_out_valid is still low. (im sending sync message)
