14 years agoPS Config using SPI EEPROM
I am working on a project using a Cyclone III device. I have the board setup to use an EPCS4 to configure the FPGA. The EPCS4 is programmed by a byte blaster.
The EPCS4 is very expensive. The design also includes a relatively fast ARM microcontroller. I would like to add the option of configuring the FPGA via an EEPROM, read by the microcontroller. I see figure 9-14 (page 193) here: http://www.altera.com/literature/hb/cyc3/cyclone3_handbook.pdf It looks like that describes a memory device that is BIT ADDRESSABLE, with the bit going to the data[0] pin of the FPGA. I would like to use a serial (SPI or I2C) EEPROM, these are byte addressable. Is it feasible to read bytes from the EEPROM and use another pin from the microcontroller to produce the data[0] bitstream? (Other microcontroller pins would produce/read the other necessary signals) Thanks! Rich2 Replies
Macronix is another manufacturer.
--- Quote Start --- The EPCS4 is very expensive. --- Quote End --- The EPCS device is simply a re-branded SPI flash. You can use devices from Numonyx and Spansion in place of the EPCS devices. Search the archives for other threads. --- Quote Start --- Is it feasible to read bytes from the EEPROM and use another pin from the microcontroller to produce the data[0] bitstream? (Other microcontroller pins would produce/read the other necessary signals) --- Quote End --- Yes. Its a pretty standard method of configuring an FPGA. Here's some notes on how to do it with another FPGA or CPLD http://www.ovro.caltech.edu/~dwh/carma_board/fpga_configuration.pdf But bit-banging with a microcontroller, or wiring the SPI port to the FPGA could be used to achieve the same thing. Cheers, Dave
