PS and JTAG combination
Refer application note AN 656
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an656.pdf
Anand
- HT47 years ago
Thanks Anand,
it was really helpful document.
I have one more question:
in Figure 2 in the document you sent, does not talk about pins: nCONFIG, CONF_DONE and nSTATUS connections in MAX10 configuration. I believe I should follow the figure 12 in MAX10 config document https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/ug_m10_config.pdf in page 35 for these pins. Is that correct?
- AnandRaj_S_Intel7 years ago
Yes, you are correct. we can ignore TRST pin for EP4CGX30 FPGA.
The TRST pin is an optional active-low, asynchronous reset input used for Joint Test Action Group (JTAG) boundary-scan testing (BST). While the
TRST pin can be helpful in systems that use it, it is unnecessary for the successful operation of the BST circuitry in Intel devices. download cable does not use this pin.
Anand
- HT47 years ago
I want to double check about the pin TSRT in figure 2 AN 656. I have ignored this pin completely with my FPGA EP4CGX30.
I am not sure if Intel has any other FPGA with this pin or not but I assume it is not valid for my FPGA plus I don't need to substitute it with some other pins.
Many thanks
Hi HT,
Yes, We have to follow the figure 12 of max 10 configuration user guide also refer pin connection guidelines.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/dp/max-10/pcg-01018.pdf
Anand
