14 years agoproperly constraining system synchronous interface
I'm trying to interface an FPGA to a DAC (running at 200MSa/s) in a system synchronous configuration. The FPGA clock and DAC clock come from the same source and then split on the PCB before going to...
14 years agoShould it not be 2.1 ns tSetup and -0.6ns tHold?
I've never seen a negative tSetup... Anyway, you're in the right path. A couple of checks: - Assign your pins and set the correct I/O standard. The delays may change a bit. - Make sure your output register is being packed into the IOE.
