8 years agoProgress FAILED !!! on the programmer.
Hello Guys; I have a problem, I can use Quartus Prime Lite Edition 15.1 so MY Project is created file that are .sof and .pof by Quartus Prime Lite Edition. I want to program my evalua...
8 years agoHi,
Perform the following steps, 1. Visual check: Factory Default Switch and Jumper Settings, FPGA chip leads, LEDs status etc. 2. To successfully use the USB-Blaster cable, disconnect it before power up the board. Once you power on the board, then reconnect the USB-Blaster cable. 3. Open Quartus II Programmer 4. Click Auto Detect(or else Check Add Device->select 10M50DAF484 ) 5. Add .sof file 6. Turn on Program/Configure option. 7. Click Start. 8. Check the nSTATUS, CONF_DONE, nCONFIG signal status. Best Regards Vikas Jathar (This message was posted on behalf of Intel Corporation)
