16 years agoProgramming the NiosII with command line
Hi, I am trying to get familiar with Nios II cyclone III, and trying to program the Nios II with hello_world example comes with the NEEK. However, it is not succeed. Here is my steps. 1. ru...
16 years ago --- Quote Start --- I fixed it. Thanks I used the example from NEEK version8.0 and run it with a version9.1. And that is the problem. I fixed it to run the example under version 8.0 --- Quote End --- Help! I have exactly the same problem. Do you mean you used NEEK files that were generated only for Quartus version 8.0? I'm building my project with Quartus 9.1, all the VHD codes and C code are generated by it but I'm using a Cyclone III board version7.2. Do you think it could be the problem?
