Programming the Altera EPM7064SLC with a POF file that specifies device as EPM7064LC. Quartus II says it can't program this device...
...is there a way to change the POF file device to the correct EPM7064SLC? Is this what I need to do? All I have is the POF file from customer. I'm not very familiar with POF files.
The Quartus II software only supports MAX 7000AE .pof cross-programming into MAX 7000B and MAX 3000A cross-programming into MAX 7000AE. All other combinations are not supported by the Quartus II software but you can program using the MAX+PLUS II software.
Kindly check the link below.
Plus, it’s not advisable to use or change the POF file for other devices.
To know more on POF file, kindly refer to the link below.
1 Reply
- CalvinJoaz_P_Intel
Contributor
