14 years agoProgramming Protocol and Format Specs
Are there available specifications for the entire process of programming an FPGA [protocols/file formats... not programming using an existing utility] (in my case a Cyclone IV)? Is the file for...
14 years agoGazmodo,
the configuration bitstream format is not documented anywhere. Best forget about that part. In order to upload the configuration bitstream into the FPGA,/PROM, Quartus can convert it into a JAM/STAPL format, which is a standard. Altera even made available source code for a JAM/STAPL player.
