Programming non volatile memory of FPGA Devkit - Intel Arria 10 soc devkit
I was able to program .jic using active serial mode.
SW5 ( MSEL (2:0)) = 010 for Active Serial Fast mode
SW4.2 = ON to disable Max V from the JTAG chain
SW6.4 = OFF to load user image from flash.
couldn't figure out .pof solution yet. but this ticket can be closed now.
thanks
- FvM3 years ago
there's a similar thread about .pof programming of this board, however not yet solved. https://community.intel.com/t5/Programmable-Devices/Flash-memory-not-detected-Arria-10-Development-kit/m-p/1534599
Selecting AS configuration works for this board because it has dual configuration flash, PP + AS.
AS configuration may be too slow to get PCIe recognized at power-on, depending on BIOS Features. Therefore PP may be preferred.
I don't have this board and can't tell if MAX V PFL implementation supports .pof programming, it basically should.
You may also want configuration update without USB-Blaster being involved. In this case, flash update has to be implemented in Arria 10, either in HDL logic or soft processor.
