12 years agoProgramming NIOS II code to EPCQ in Quartus 13.1
Hello I'm having trouble with NIOS II code executing from an EPCQ x4 flash chip (p/n Micron N25Q256A) after a power cycle. I've followed the following guideleins to boot from EPCQ or EPCS (fro...
12 years agoYou don't specifically say whether your hardware can successfully boot the FPGA from the EPCQ device. Can it? Forget Nios, just a simple rtl only project that, for example, flashes an LED.
--- Quote Start --- ...after a power cycle, all pins are in tri-state... --- Quote End --- This implies the FPGA's isn't booting at all. So, I presume the only method you have of programming the FPGA is via JTAG. Is that right? What method are you using to program the EPCQ device? Is this custom hardware or a development kit? Let me know and I will see if I can help. Regards, Alex
