8 years agoProgramming file for EPCQ128A flash with Cyclone III FPGA
Has anyone tried generating a programming file (.jic) for the EPCQ128A flash memory for a Quartus project that was originally using the EPCS128 flash memory with Cyclone III FPGA? We are using Quartu...
8 years ago --- Quote Start --- Hi John, Have you recompile your design with EPCQA selected instead of EPCQ? You're supposed to select EPCQA in Serial Flash Controller, and also during JIC file generation. If you're programming the EPCQA with EPCQ programming file it might not work. --- Quote End --- Thanks aaronchng i will look into it and report results
