14 years agoProgramming EPCS with FPGA config and NIOS II with AS
Hello, Please excuse me for this newby question. I have configured a NIOS II processor for a FPGA and written a small program. The NIOS II processor has a EPCS-interface for programming the ...
14 years agoHello Daixiwen,
Thank you taking the time to look at my question. To see if I understand everything correct could you have a look at the below text and correct it if needed. I have programmed the EPCS-flash with my fpga-configuration (contains NIOS II processor and some logical gates and my application) - After powering up the FPGA it will load its configuration-data from the EPCS-flash. - Then the NIOS-processor will be started with its boot-loader. - The boot-loader will load my application from the EPCS-flash into the RAM connected to the FPGA and jump to the starting-point of my application. Thank you and best regards, Wamor
