8 years agoProgramming EPCS with altasmi_parallel
I have a Cyclone 3 with EPCS16 that I'm trying to program through an RS232 serial connection to a remote host. I'm using altasmi_parallel and altremote_update as follows:
1. Generate the hexout file in Quartus 2 2. Erase the EPCS16 using altasmi_parallel builk erase 3. Write each byte of the hexout file (also reverse he bits) to the EPCS using altasmi_parallel writes (starting at address 0). 4. Pulse the reconfig signal on the altremote_update block 5. Reboot the system (Just in case) The firmware doesn't update and the old behavior still persists. Any ides if I'm missing a step? Thanks!No RepliesBe the first to reply
