11 years agoProgramming EPCS Devices With a Processor
Hi, First, I've searched the forum for hits on this topic. In the first few dozen of hits, I didn't see anything that fit. So I apologize in advance if the answer is buried deep somewhere tha...
11 years agoThe document contains the reference section for the sof2flash utility.
It is normally used in conjunction with the nios2-flash-programmer, which in your case you would not be using since you are trying to program the EPCS directly. In case it wasn't clear, you can't just "translating from .sof to S-records"; you have to use sof2flash which understands the (undocumented) structure of the .sof and generates the S-records.
