15 years agoProgramming CPLD's with Hexadecimal files
Hi everybody,
Is it possible to program an EPM570T100 using a Hexadecimal (Intel-Format) Output File for SRAM ? It seems not since Quartus will not generate this file when I go under Settings, Device and Pin options and select programming files Hexadecimal (Intel-Format). Also - if I try and convert the prgramming file under File- convert programming files and select the Hexadecimal (Intel-Format) Output File for SRAMthe toll insists on having a SOF file as input, POF is not allowed. If it is possible to to program an EPM570T100 using a Hexadecimal (Intel-Format) Output File for SRAM, how do I go about generating this file in Quartus ? Thanks, EricNo RepliesBe the first to reply
