14 years agoProgramming circuit
Hi, im trying to build a circuit board containing a cyclone-III and the necessary programming logic and I'ld like to keep it as cheap as possible. I have the following questions: I originall...
14 years ago --- Quote Start --- The CPLD would be used to program the FPGA. --- Quote End --- Why can't you program the FPGA directly from the flash? I think that is the common way we use configuration schemes like Active Serial, Active Parallel.
