17 years agoProgramming and booting a non-NIOS embedded apllicatio
Hi, I wonder if anybody have already tried or can share ideas how to load a non-NOIS embedded program into a configuration EPCS device or separate SPI or CFI flash by means of the Quartus/NIOS ...
17 years ago --- Quote Start --- Hmmm.... Did you not see the SPI bootloader that is provided by Altium? It was added to the library - I believe - some time around Altium Designer 6.8 (When the NB2 was first released). It is a simple state machine slave core to the tSK3000 (or NIOS-II) that uses a Wishbone multi-master to write the boot code from an SPI flash device to the program memory (SRAM). --- Quote End --- Yes, I know this module and even wanted to use it at the beginning, but afterwards decided to use SPI_WB (w/o the HW-coded booting), having implemented both programming the flash with my application and booting it to the program SRAM from within my program. Besides, I use the same flash to save and read the application's non-volatile data. This way seemed to me to be more controllable and after all consumed less LE resources then it would be with WB_BOOTLOADER. Valmar
