17 years agoProgramming and booting a non-NIOS embedded apllicatio
Hi, I wonder if anybody have already tried or can share ideas how to load a non-NOIS embedded program into a configuration EPCS device or separate SPI or CFI flash by means of the Quartus/NIOS ...
17 years agoJake,
thank you once again. Now I've got a much better insight in your idea. Here's my understanding of your approach in form what I shall do with estimation how it might be complex or easy for me to implement: 1) adapt the APCS component from you to interface to my processor. I see no problem with it. As I understand, there's no need to change the EPCS interface of the core, if I use a standard Altera device; 2) modify my bootloader to make it able to copy the program out of the EPCS in the SRAM. Currently it can boot only from an SPI-Flash hooked up on five standard IO-pins of the FPGA. Here I fill a need to study more in-depth what and to what to change. 3) Use the changed and compiled bootloader as a .mif for the ROM block in the EPCS. What file shall I take for that - the executable .elf? No special tricks or actions else? Valmar
