RandyR
5 years agoProgramming a CycloneV device when not using the SoC
This is a follow on post............
If I use a CycloneV device, but do not intend to use the SoC portion, is there a programmer setting that will not require jumping through hoops as described ab...
YuanLi_S_Intel
5 years agoSorry for the inconvenient cause. I think this is how Quartus Programmer works when you click auto-detect. It will include all the component in the chain. When you add the JIC file, you must either device all the non-programing component / tick only the device which you are programming. I hope this help. Cheers
