17 years agoProgramming a custom board without flash memory
I have a custom board (Stratix-II with an EP2S90F1020C3). Right now the functionallity is only described in HDL and it's working fine. However, the board does NOT have any flash memory. Now I w...
17 years agoHey hey :-)
just wanted to tell you that it's working now ;-) I made a small reset generator which sets at the very beginning the reset_n signal to 0 and afterwards to 1 ... the other way around results in the same error as above.. now I can start to create the whole system, since it's at least working with this simple solution :-) thanks again !
