17 years agoProgramming a custom board without flash memory
I have a custom board (Stratix-II with an EP2S90F1020C3). Right now the functionallity is only described in HDL and it's working fine. However, the board does NOT have any flash memory. Now I w...
17 years agoaltera_nios2 9.0 / fast with debug level 1 (I also tried 2 and 3)
the problem is that I cant download the software project .. I get the mentioned error message if i try :-/ edit: I created a Quartus II project and designed the system using SOPC Builder; It only consists of a cpu, on chip memory and a JTAG UART interface. Then I assigned a pin for the clock and dowloaded the *.sof to the chip. If I run NIOS IDE and try to dowload a simple project, I get the error message ...
