17 years agoProgramming a custom board without flash memory
I have a custom board (Stratix-II with an EP2S90F1020C3). Right now the functionallity is only described in HDL and it's working fine. However, the board does NOT have any flash memory. Now I w...
17 years agoWhat NIOS core did you use? Does it have the debug functionality enabled?
Do you keep the USB blaster connected to your board when you run your project? You can run NIOS projects without a flash memory, it shouldn't be a problem.
