A-Ismail
5 years agoProgramming 10M08SAE144C8G & 10M08SAE144I7G with the same pof
Hello
We have been using 10M08SAE144C8G for our product. Due to part shortage we can only source 10M08SAE144I7G .
Can we use the same programming file (*.pof) from 10M08SAE144C8G with the new ...
YuanLi_S_Intel
5 years agoyes. it can be.
A-Ismail
5 years agoHi Bruce
It seems you answer is contradicting to the answer given in the link above
To ensure that the timing model is correct, you should choose the device in Quartus® II software that matches the temperature rating marked on the device.
Based on our experience, on the same design, when we choose a different speed/temperature grader. The Quartus will generate a different binary programming files.
What is the correct path for us when we change the device from C8 to i7
a) use the same binary programming file from C8 on i7 device
b) recompile the design with new i7 target device and generate new binary programming file
A Ismail
