A-Ismail
5 years agoProgramming 10M08SAE144C8G & 10M08SAE144I7G with the same pof
Hello
We have been using 10M08SAE144C8G for our product. Due to part shortage we can only source 10M08SAE144I7G .
Can we use the same programming file (*.pof) from 10M08SAE144C8G with the new ...
YuanLi_S_Intel
5 years agoHi,
Yes it can be. Programming file are independent from temperature grade.
Bruce
A-Ismail
5 years agoHi Bruce
Thank you for prompt reply. Pls confirm that the programming file with the design timing ( (STA) closed with C8 target device can be safely used on i7 device , means the design will work on i7 device as exactly as it is on C8 device.
A-Ismail
