11 years agoProgrammer fails at 87% - SoCKit
Hi, I am using SoCKit Development Kit. Programmer fails always at 87% and it doesn't show any error. Sometimes, when the programmer fails at 87% or 88%, I can still see program got burned...
11 years agoI have already tried those actions. When current code fails to burn, I can successfully burn simple LED blinking project.
I am trying to see LVDS outputs. I read somewhere that LVDS signals can't be seen on signal tab, therefore, I am not using any differential signals such as bit clock. I am using frame clock as main clock and reset to trigger the Signal Tab. I successfully burned the program for one channel with this setting but for 8 channel with the same setting, it fails at 87%. For one channel output, I just activated LED and now the programmer fails again at 87% but I can see LED blinking which means part of program is still there but Signal Tab is not activated. If anyone tried to see LVDS output, can please comment here. Thanks.
