Program verificaion failure
I am trying to program an EP3SE50F484C2 in FAST ACTIVE SERIAL mode using an EPCS16 configuration device. I have compression turned on. It worked the first time with a passing verification. The second and all subsequent time verification fails. I have replaced the EPCS16 twice with no success. When run examine I get a different check sum each time, as if it were reading garbage. I have programed the gate array using the JTAG port successfully and the programed EP3SE50F484C2 operates properly. What can I do short of replacing the gate array.
Thanks for your assistance
1 Reply
- NurAiman_M_Intel
Please be noted that EP3SE50F484C2 has been obsolete hence we have limited information for the device. However it is recommended to refer to Stratix III handbook(page 349) for further information on Fast Active Serial and EPCS datasheet for EPCS.
Stratix III handbook:
EPCS datasheet:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/cfg/cyc_c51014.pdf
Thank you.
Aiman
