risic2024
2 years agoprogram successfully but output always high
hi, I am confused by EPM240T100C5,have tried many ways, but still failed, please give me some advices, thanks. It indicated the programming is successful, but output always stay high. even only as...
anonimcs
Contributor
2 years agoHi,
Did you add any pin constraints ?
risic2024
2 years agohi,glad to get response from you, thanks.
surely, SDC file is applied correctly. It seems that EPM240 can't enter user mode.please find the attached log for details.
- anonimcs2 years ago
Contributor
Did you also test with the other board (EPM1270T144C5) and see that the output pins become 0V ? If that's the case, then I'm not sure what else the issue might be..
- risic20242 years ago
yes, but EPM1270T144C5 is only for reference, we should focus on EPM240T100C5. anyway thanks.
