15 years agoprogram EPCS flash
Hi everyone, I am trying to configure an EPCS4 device on a BeMicro board (cyclone 3 FPGA). Thus I have added a EPCS flash controller in the SOPC builder and configured the pins DCLK, nCEO, Data...
15 years agoCan you copy the text and paste it into the forum to see the complete error message... I don't see everything from this line...
Some basic questions: Did you also add the pins to your toplevel, connected them to the right pins of your FPGA and connected them to your NiosII? E.g. Toplevel: --epcs flash device iFlashData0 : in std_logic; oFlashDClk : out std_logic; oFlashSce : out std_logic; oFlashSdo : out std_logic; NiosII instantiation: -- the_epcs_controller data0_to_the_epcs_controller => iFlashData0, dclk_from_the_epcs_controller => oFlashDClk, sce_from_the_epcs_controller => oFlashSce, sdo_from_the_epcs_controller => oFlashSdo, In Device and Pin options > Configuration and you have enabled "User configuration device" and you selected the EPCS. There is standard no EPCS, but you soldered the EPCS4 to the board?
