18 years agoProcessor not responding
Hi all , I developed a custom component(memory mapped). When I integrate it with the NIOS II processor in the sopc builder and try to run the NIOS II embeded systm as hardware I get the er...
15 years agoYou have to check which kind of reset comes from your board (reset 'button'). If this is an active high signal you will have to invert it in your code. If it's an active low signal you will have to check in your code that you don't invert it.
