16 years agoProcess involved in loading POF file from flash
I am currently in the process in trying to make a custom board that has a FPGA. One of the things I want it to do, is to be able to power on and load a POF file without having to be programmed throug...
16 years agoin this case you wrote to flash using the FPGA PFL, but when the board was rebooted, the MAX II was actually the PFL which read the CFI and configured the FPGA
it is a bit confusing
